Problem with images in main page
Good night and happy new year!
I detect a little problem with an images in my main page.
Let me explain you.
I have a module Big grid Slide in the main page.
When I put some pictures, are dropped by down and only are dropped here. When I clic in the post show correct in the other sites ( for example in the up of the article ).
The image appears fine in the other blocks. For example (Blocks 17)
I invite you to access my website https://www.binaryworld.es and see that I am talking.
I see that the images are resizing but in this module don’t resize correct .. in change in other modules fine…
I hope you can help me.
Thanks and regards
Please try and regenerate the thumbnails, using this guide
– https://forum.tagdiv.com/thumbnails-fix-strange-looking-images-on-blocks/
This process will recreate all the thumbnails from the featured images or videos you have set for the posts. Seems the thumbnails are not created properly at the moment.
Good morning Simion C.,
my problem is with all imagens ( new and older ). For example, I wrote yesterday a new post and don’t generate the thumbnails fine.
The others size are fine.
Let me add more information. I am using Shortpixel Plugin with optimize images (automatically).
Thanks and regards,
Sergio
Yes it seems some thumbnails are not created properly. Please try to deactivate the plugin you mention, and then regenerate again if possible. Check if all the thumbnails look as they should.
Note the requirement for the server mentioned in the guide, that is needed for the regeneration process to work. You could contact the hosting provider and ask if the the GD library is installed on the server.
By default the theme creates the necessary thumbnails automatically, most related image issues are caused by plugins.
