Problem with images in Smart Lists
Hi!
I´m having a problem when i put an image into a Smart List.
As you can see, when i write the article, i´ve just one photo, but when i make a preview i see two.
How it looks in edition mode
How it looks in preview
I´ve selected Style 5 in post settings and Heading 2
Thanks you!
Hello romerito13,
I have tested on my side and everything seems to work as expected, not with the twice image. I suspect being a problem with cache memory. Please try to clear all cache and check again and see how it works.
Thank you for the message!
Hi Catalin!
I´ve have deleted cache and still happening…
Can i sent you a direct message to give you access to try it?
Hello romerito13,
If you are using Photon module from Jetpack plugin, please try to disable it and see if your problem is still there. This kind of feature seems to be incompatible with our theme and therefore, these errors occur. If your problem persists after this advice, please send us an email at contact@tagdiv.com with your credentials so we can further inspect the issue. Also, please provide the link of this topic so we know who you are and what the issue is.
