Problem with images while updating to N8
I have updated to Newspaper8 from 7 and now all pictures in every page (not in posts) are full width screen and I select a different size in the visual composer as I have done always but it’s not working.
I have tried to delete the pics and add new ones but same issue happened.
Any idea?
  • This topic was modified 9 years by utzgurx.
And now I realized that the images that have a link to a URL, this link is not working, when clicking the image it send me to the top of the actual page where the image is.
Edit: and images without any link do the same, they send me to the top of the page. I hope this info is helpfull.
Thanks a lot.
  • This reply was modified 9 years by utzgurx.
Hello utzgurx,
I have inspected your website -> https://www.mallorcaglam.com/ and I did not saw any problem with your images. Please provide more details, screenshots with your problem so I will be able to identify it and also, if it is not your website, provide your URL so I can take a closer look at it.
All images except the post images.
Look at https://www.mallorcaglam.com/quienes-somos and you will see.
Also, you can check another website https://www.gerardx.com and see the same problem.
I can select the height, but the width is full screen, even if I select for example 100×100 it shows full widht. I have to use TadDivComposer (blue second button on the top of editing pages) to change the height, because using visual composer al always there is no way to change it, simply it doesn’t work.
Hello utzgurx,
Here is talking about the single image which is added to a page, like this -> https://www.screencast.com/t/UtOjRBRWJVjL and also, notice that your images are displayed in full width because you are using the 1/1 layout and that’s why the image will be loaded in full width. Change the layout to 1/3+1/3+1/3 or 2/3+1/3 and check the results.
No, I’m using different layouts (it happens to me to some websites in different pages with different layouts).
I add an image who show you one of these layouts.
Anyway, if I use a layout 1/1 and choose image 100×100 for example, it must shows 100×100, because if I use different layouts it will be the size of the 1/3 like you mean and I have been always since I’m using Newspaper to choose the size. It’s one of the features of the object image when you add it, but anyway this is not for sure the problem as I showed you.
In other website if I choose layout 1/2+1/2 for example the image appeared cutted as this size. I will try to explain with an example. Imagine an image 2000×2000, I select for example 300×300 as I need, then the image is showed as the size of 1/2 of the page, but cutted, not reduced to this size, just cut and show a part of this 2000×2000. Do you understand what I mean? The big problem here is after upgrade to Newspaper8 I’m not able anymore to choose any size of the images and see al of them huge and cutted.
I hope this info help you to understand the problem.
Here is the example of 1/4 of https://www.mallorcaglam.com/quienes-somos
Example
Must be something very wrong, because these images are linked to one page (everyone has his own personal page) and when clicking (try it) the image linked it move the mouse to the top of the page.
I checked the links and are ok. I have tried to delete the images and add new ones and happened the same.
It happens to me to my 3 webs I have updated to Newspaper8.
I tried to go back to version 7.8 (tried in one of the 3 webs) but I see this, it seems it’s now 7.8v but I still see the logo of version 8 and the same problem still happens. No links working, no customizable size of images, etc.
This is at http://www.rozyo.com
Theme
I keep trying things in order to have more info to tell you and solve this issue faster.
I have tried to add an image without using Backend Editor, just adding an object trough wordpress editor and it’s working all fine.
All of this start happens when I updated from 7.8 to 8 version, and it happened to all my sites (I use Newspaper in all of them), so must be something wrong with that we can fix, because obviously is the same problem and due to the upgrading to v8.
Visual composer, WordPress, and all other plugins are up to date also.
NEW INFO!
I have disabled the new plugin tagDiv composer (wich installed when I updated to v8) and now I see all like before.
So, how can I use the new utility as this new composer without problems?
Thank you very much!
Hello utzgurux,
If your website is anchored in Visual Composer, you will have to further use the Visual Composer plugin, sorry! Notice that our page builder is a required plugin and the transitions between these two pages builders can be done only on the manually way, sorry! For more information about transition between these two-page builders, please check our documentation here -> https://forum.tagdiv.com/tagdiv-composer-tutorial/ -> https://forum.tagdiv.com/visual-composer-tagdiv-composer-transition/
From now on, the TD Composer plugin will be improved with some features which have to be exclusively for this builder.
What means “our page builder is a required plugin”?
Must I have it activated? Because now I have it disabled and everything is fine.
I prefer Visual Composer because it allows to choose the weigh of the image and its a feature that I need in all my sites and I didn’t find it in your TD composer.
Hello utzgurx,
I mean that our TD Composer is required, in the sense that in the future, all of the features will be developed on our page builder which will not work as properly with Visual Composer. You can further use Visual Composer but you have to take this into account. Also, for more information about transition between these two plugins, please consult the following documentation here -> https://forum.tagdiv.com/tagdiv-composer-tutorial/ -> https://forum.tagdiv.com/visual-composer-tagdiv-composer-transition/
I had approximatively the same problem. New to Newspaper, I started with 8.1 choosing to use VC (I already knew it… lazy boy:-)). The first time I used an image element beside a text element, I had a wierd result with a stretched image, full width but truncated in height. Reading the utzgurx’s experience, I’ve tried to desactivate TD Composer… and well… everything run’s norml now. I definitely would have prefered to have the ability to test your composer besides VC.
However thanks for such a brilliant theme.
