Problem with images
Hi! The Newspaper 8 theme doesn’t publish images on my site. There are images in console but in fact it looks like this:No images
Hello 2rybinsk,
Please ensure that you have right made your theme installing via FTP way and then, check your system status parameters to be according to our documentation here -> https://forum.tagdiv.com/system-status-parameters-guide/ Also, if you are using some untested plugins which can cause some interference, try to remove all of them, clear all the caches and check the results.
Thank you for advice! The problem was with one of the plugins.
Now I have another inconvenience. Images have different sizes and I’ve got these grey gaps:
What should I do for solving this problem? I want the system automaticly optimize sizes picking them from articles and resizing for grids.
And why is it impossible to change the order of articles in grids manually? There are so many options like “latest”, “oldest”, and “a-z” but there is no simple opportunity to make it by myself.
Hello 2rybinsk,
You can use this guide to regenerate the thumbnails if they are not displaying properly
– https://forum.tagdiv.com/thumbnails-fix-strange-looking-images-on-blocks/
After the regeneration process is complete, please clear any caching installed.
