Problem with inserting Single External Shortcode on Home Page
Hi guys 🙂
inserting shortcode in Post(s) via “Single External Shortcode” element works as shown in the screenshot https://prnt.sc/26gwigr
on the Home Page I think there is a problem with tagDiv Composer:
1. inserting shortcode via “Raw HTML” element does not work https://prnt.sc/26gwkna
2. when I click on “+Add” (Add a new element in the viewport) and when I search for “shortcode” https://prnt.sc/26gwjep or “external” https://prnt.sc/26gwk2z shows no results
can you please fix this bug?
thank you in advance
Hello @zlobica!
For homepage, please use “Column text” and “text with title” elements which have a button called “edit content” and if you click on that button, the WP Editor will open and you can add the code there. Close the WP Editor from X, save the changes from Composer and view the page to see the changes.
The Single External Shortcode works only on single post templates. Also, you can set for this one https://prnt.sc/26gwigr in the CSS tab a margin:0 at the bottom to take off that space.
I inserted a shortcode with “Column text” and everything is fine … 🙂
thank you Bettina 🙂
