Hello, I ran into another template issues. Apart from the error that appears during the installation of revolution slider (the problem is not solved, I wrote another post about it – support does not respond to the message), there are errors when installing the plugins. I wanted to install Yoast seo, I get a fatal error after installing and enabling the plugin. I can’t do anything else. Then I have to go to the server and remove the plugin, then the website is back to normal. I tried to install other plugins: All in one seo pack, Wp forms, but with every other plugin I get bugs and won’t turn on. The problem also appears when trying to uninstall. It is impossible to remove plugins from the WP panel, I have to remove them manually from the plugins folder on the server.
How do I fix these problems? Why can’t I install plugins?
What I see after installing other plugins:
All in OneSeo Pack:
Fatal error: Uncaught mysqli_sql_exception: Table ‘srv41318_wp1.wp_actionscheduler_actions’ doesn’t exist in /home/srv41318/domains/doradnik.pl/public_html/wp-includes/wp-db.php:2056 Stack trace: #0 /home/srv41318/domains/doradnik.pl/public_html/wp-includes/wp-db.php(2056): mysqli_query(Object(mysqli), ‘DESCRIBE wp_act…’) #1 /home/srv41318/domains/doradnik.pl/public_html/wp-includes/wp-db.php(1945): wpdb->_do_query(‘DESCRIBE wp_act…’) #2 /home/srv41318/domains/doradnik.pl/public_html/wp-includes/wp-db.php(2695): wpdb->query(‘DESCRIBE wp_act…’) #3 /home/srv41318/domains/doradnik.pl/public_html/wp-admin/includes/upgrade.php(2749): wpdb->get_results(‘DESCRIBE wp_act…’) #4 /home/srv41318/domains/doradnik.pl/public_html/wp-content/plugins/all-in-one-seo-pack/vendor/woocommerce/action-scheduler/classes/abstracts/ActionScheduler_Abstract_Schema.php(117): dbDelta(Array) #5 /home/srv41318/domains/doradnik.pl/public_html/wp-content/plugins/all-in-one-seo-pack/vendor/woocommerce/action-scheduler/classes/abstracts/ActionScheduler_Abstract_Schema.php(45): ActionScheduler_Abstract_Schema->update_table(‘actionscheduler…’) #6 /home/srv41318/domains/doradnik.pl/public_html/wp-content/plugins/all-in-one-seo-pack/vendor/woocommerce/action-scheduler/classes/data-stores/ActionScheduler_DBStore.php(25): ActionScheduler_Abstract_Schema->register_tables() #7 /home/srv41318/domains/doradnik.pl/public_html/wp-content/plugins/all-in-one-seo-pack/vendor/woocommerce/action-scheduler/classes/data-stores/ActionScheduler_HybridStore.php(57): ActionScheduler_DBStore->init() #8 /home/srv41318/domains/doradnik.pl/public_html/wp-content/plugins/all-in-one-seo-pack/vendor/woocommerce/action-scheduler/classes/abstracts/ActionScheduler.php(158): ActionScheduler_HybridStore->init() #9 /home/srv41318/domains/doradnik.pl/public_html/wp-content/plugins/all-in-one-seo-pack/vendor/woocommerce/action-scheduler/action-scheduler.php(44): ActionScheduler::init(‘/home/srv41318/…’) #10 /home/srv41318/domains/doradnik.pl/public_html/wp-content/plugins/all-in-one-seo-pack/vendor/woocommerce/action-scheduler/action-scheduler.php(49): action_scheduler_initialize_3_dot_1_dot_6() #11 /home/srv41318/domains/doradnik.pl/public_html/wp-content/plugins/all-in-one-seo-pack/app/AIOSEO.php(230): require(‘/home/srv41318/…’) #12 /home/srv41318/domains/doradnik.pl/public_html/wp-content/plugins/all-in-one-seo-pack/app/AIOSEO.php(171): AIOSEO\Plugin\AIOSEO->includes() #13 /home/srv41318/domains/doradnik.pl/public_html/wp-content/plugins/all-in-one-seo-pack/app/AIOSEO.php(155): AIOSEO\Plugin\AIOSEO->init() #14 /home/srv41318/domains/doradnik.pl/public_html/wp-content/plugins/all-in-one-seo-pack/app/AIOSEO.php(395): AIOSEO\Plugin\AIOSEO::instance() #15 /home/srv41318/domains/doradnik.pl/public_html/wp-content/plugins/all-in-one-seo-pack/all_in_one_seo_pack.php(94): aioseo() #16 /home/srv41318/domains/doradnik.pl/public_html/wp-admin/includes/plugin.php(2286): include_once(‘/home/srv41318/…’) #17 /home/srv41318/domains/doradnik.pl/public_html/wp-admin/plugins.php(191): plugin_sandbox_scrape(‘all-in-one-seo-…’) #18 {main} thrown in /home/srv41318/domains/doradnik.pl/public_html/wp-includes/wp-db.php on line 2056
Wp forms:
Fatal error: Uncaught mysqli_sql_exception: Table ‘srv41318_wp1.wp_actionscheduler_actions’ doesn’t exist in /home/srv41318/domains/doradnik.pl/public_html/wp-includes/wp-db.php:2056 Stack trace: #0 /home/srv41318/domains/doradnik.pl/public_html/wp-includes/wp-db.php(2056): mysqli_query(Object(mysqli), ‘DESCRIBE wp_act…’) #1 /home/srv41318/domains/doradnik.pl/public_html/wp-includes/wp-db.php(1945): wpdb->_do_query(‘DESCRIBE wp_act…’) #2 /home/srv41318/domains/doradnik.pl/public_html/wp-includes/wp-db.php(2695): wpdb->query(‘DESCRIBE wp_act…’) #3 /home/srv41318/domains/doradnik.pl/public_html/wp-admin/includes/upgrade.php(2749): wpdb->get_results(‘DESCRIBE wp_act…’) #4 /home/srv41318/domains/doradnik.pl/public_html/wp-content/plugins/wpforms-lite/vendor/woocommerce/action-scheduler/classes/abstracts/ActionScheduler_Abstract_Schema.php(117): dbDelta(Array) #5 /home/srv41318/domains/doradnik.pl/public_html/wp-content/plugins/wpforms-lite/vendor/woocommerce/action-scheduler/classes/abstracts/ActionScheduler_Abstract_Schema.php(45): ActionScheduler_Abstract_Schema->update_table(‘actionscheduler…’) #6 /home/srv41318/domains/doradnik.pl/public_html/wp-content/plugins/wpforms-lite/vendor/woocommerce/action-scheduler/classes/data-stores/ActionScheduler_DBStore.php(35): ActionScheduler_Abstract_Schema->register_tables() #7 /home/srv41318/domains/doradnik.pl/public_html/wp-content/plugins/wpforms-lite/vendor/woocommerce/action-scheduler/classes/data-stores/ActionScheduler_HybridStore.php(57): ActionScheduler_DBStore->init() #8 /home/srv41318/domains/doradnik.pl/public_html/wp-content/plugins/wpforms-lite/vendor/woocommerce/action-scheduler/classes/abstracts/ActionScheduler.php(158): ActionScheduler_HybridStore->init() #9 /home/srv41318/domains/doradnik.pl/public_html/wp-content/plugins/wpforms-lite/vendor/woocommerce/action-scheduler/action-scheduler.php(48): ActionScheduler::init(‘/home/srv41318/…’) #10 /home/srv41318/domains/doradnik.pl/public_html/wp-content/plugins/wpforms-lite/vendor/woocommerce/action-scheduler/action-scheduler.php(54): action_scheduler_initialize_3_dot_2_dot_1() #11 /home/srv41318/domains/doradnik.pl/public_html/wp-content/plugins/wpforms-lite/src/WPForms.php(221): require_once(‘/home/srv41318/…’) #12 /home/srv41318/domains/doradnik.pl/public_html/wp-content/plugins/wpforms-lite/src/WPForms.php(177): WPForms\WPForms->includes_magic() #13 /home/srv41318/domains/doradnik.pl/public_html/wp-content/plugins/wpforms-lite/src/WPForms.php(114): WPForms\WPForms->includes() #14 /home/srv41318/domains/doradnik.pl/public_html/wp-content/plugins/wpforms-lite/src/WPForms.php(402): WPForms\WPForms::instance() #15 /home/srv41318/domains/doradnik.pl/public_html/wp-content/plugins/wpforms-lite/wpforms.php(230): wpforms() #16 /home/srv41318/domains/doradnik.pl/public_html/wp-admin/includes/plugin.php(2286): include_once(‘/home/srv41318/…’) #17 /home/srv41318/domains/doradnik.pl/public_html/wp-admin/plugins.php(191): plugin_sandbox_scrape(‘wpforms-lite/wp…’) #18 {main} thrown in /home/srv41318/domains/doradnik.pl/public_html/wp-includes/wp-db.php on line 2056
Please contact your host about this issue, this issue may occur due to restrictions set by the host.
Also, please check those articles:
-> https://isotropic.co/unable-to-add-or-delete-plugins-heres-the-fix/
-> https://www.wpbeginner.com/plugins/why-cant-i-add-or-install-plugins-in-wordpress/
If you sent an email, then we will take a look and reply to you as soon as possible.
