Problem with interscroller banner
It seems there is a compatibility issue that doesn’t permit to interscroller banner to work. The class .td-fix-index automatically add by td-composer plugin blocks the z scroll. The site is http://www.tennisfever.it
Please, could you check and fix the problem?
Hello @Stexs !
In order to avoid misunderstandings, please provide more information(screenshots/video) about what exactly you need to achieve or what is the issue there.
Hi Bettina, in each article, after the main photo, there is an interscroller banner https://snipboard.io/VQWupj.jpg. But it doesn’t work, it doesn’t scroll. It should be so: https://ad.economia.cz/en/mobile-en/mobile-interscroller-en/
It seems that the class .td-fix-index automatically add by td composer plugin blocks the z scroll. https://snipboard.io/7s0UQD.jpg
Hello @stexs !
Try to add a class in tagdiv Composer https://prnt.sc/wNImXCbQc-0f for the raw html element. For example: .your-class
And the CSS code in Newspaper -> Theme panel -> Custom code -> Custom CSS:
.your-class .td-fix-index { transform:none!important;}
Let me know the results!
Now works!! Thank you very much.
Stefano
Hello Stefano!
I’m glad I could help you!
Let me know if you need further assistance.
Thank you for your feedback!
Thanks again. But I’m going back to writing because I’ve verified that the problem hasn’t been resolved in the infinite scroll. Is there a way to fix there too?
Hello Stefano!
This will require custom work, which is not covered by the support team because it’s a complex task to achieve.
For customization and other services, you can contact our custom work team here: https://tagdiv.com/premium-customization-services/.
Thank you for understanding!
Ok thanks.
Stefano
