Problem with Ipads/Iphones
Our website dont work on Ipads and Iphones, only blank page or server error. Any idea why?
Hello damian,
Please provide your website so I can inspect it closer. First of all, if you are using some untested plugins, please try to remove all of them and install only the plugins that come bundled with the theme and rule out any conflicting plugins.
Website adress: ndie.pl
We added SSL to our website, we think this can be a problem.
Please try to disable all plugins except visual composer, clear cache and reset cdn files if you use it. If there is a plugin conflict, this will remove it. If the problem is still there without plugins, please check your ssl implementation and remove your modifications to see if that is the cause.
Here is a guide on how to properly add ssl to WP: http://www.wpbeginner.com/wp-tutorials/how-to-add-ssl-and-https-in-wordpress/
Bogdan B
Ok, we found source of problem: WP Super Cache
If caching is ON then website on Ipads/Iphones dont work. You have any solution?
WP super cache has an issue on mobile and maybe it affects your site in that regard. We have no such reports but you can try this fix to see if it works:
https://forum.tagdiv.com/topic/mobile-theme-problems-3/
SOLVED.
The problem was with Nginx version with HTTP2 and ssl combination. We changed too Apache with no support for Nginx and now all works well. 🙂
Thanks Anyway!
