For some reason when I switch from ‘text’ to ‘visual’ on the post creation page, WordPress is breaking the content inside ‘thead’ (table headings)
I spent some time researching why this could be happening, and I found a reference to it on Stackoverflow that suggested it was theme related:
Please see this screenshot demonstrating the issue.
This topic was modified 10 years by
GadgetViper.
Hello GadgetViper,
Please notice that until now we do not have any bad reports in this regard and we cannot provide any response in this case because I cannot recreate this issue, sorry! Please ensure that you are using the latest version of the theme and required plugins (Visual Composer 4.11.2 and Social Counter 4.1) and also, the latest version of WordPress (v.4.5.3). Clear all your caches and check again.
So, if your problem is still there, please try to switch your theme to a default one and check the behaviour in this case. For more details, you can make a mini-video so I can see what happens this problem.
Hi Catalin,
Thanks for taking the time to respond. I’ve managed to find a work around using CSS.
I ended up removing the ‘thead’ and ‘th’ table.
I switched this:
<thead>
<th>Brand</th>
<th>Model No.</th>
<th>Capacity</th>
<th>USB ports</th>
<th>Max output</th>
<th>Price*</th>
<th>Buy Online</th>
</thead>
To this:
<tr class="hide-mobile hbold">
<td>Brand</td>
<td>Model No.</td>
<td>Capacity</td>
<td>USB ports</td>
<td>Max Output</td>
<td>Latest Price*</td>
<td>Buy Online</td>
</tr>
Then I created a CSS class for the ‘tr’ (hide-mobile) that hides the top header row when the table collapses on mobile views.
Think it works pretty well when you reduce the page width, you can see it working here – http://gadgetviper.com/best-power-bank-20000mah-review/
The important thing is that I can toggle between visual view and html when editing the post in WordPress without it breaking the tables 🙂
