Hi, I’m using the “Summer pro” post layout.
On the right sidebar I have “flex block 1” with the last 3 posts of the “current category”.
The problem is that I also see the current post.
So, if I see the last post from the “sports” section, there will be the same post on the right sidebar.
I can’t set an offset, because the problem is dynamic (it shows up with the last post or even with the last second post, etc.)
I await support.
Thank you
