Problem with latin-exended fonts
I wanted to speed up my website so I used LiteSpeed plugin. But now i lost Montserrat font on Polish letters like “ę, ć, ź etc”.
I have found the instruction how to add latin-extended fonts here: https://forum.tagdiv.com/newsmag-using-custom-fonts/ but on my Theme Settings there is no option like this.
Where to find it?
This situation is related to teh settings from the LiteSpeed plugin that are applied over the Google fonts. What I will suggest is to use a plugin to load locally the fonts https://wordpress.org/plugins/host-webfonts-local/
I tried this. All polish signs were displayed in Montserrat and all others with Verdana (default error font). Any other idea?
Ok,
First, let’s make sure we correctly identify the issue and move in the right direction.
When the LiteSpeed Cache plugin was not installed, was everything working correctly?
If so, then the first step should be to review the LiteSpeed Cache settings. This plugin includes options that can remove Google Fonts, so those options should be disabled. Instead, you should use the plugin I mentioned in the previous message.
