Problem With Layout
Sometimes my web loads with broken layout – screen shot – https://unsee.cc/masuzedi/
What’s the problem?
Hello Poteris,
Please try to disable all the active plugins, leave just Visual Composer to active, clear all your caches and install only the plugins that come bundled with our theme and rule out any conflicting plugins. Clear all your caches, remove server caches (if you do not have any access to do it, request this task to the service provider).
