Problem with leaving comments.
Hello I deactivate the rule to to leave a commento only with the access of an registered account but I can’t anyway: https://nuovaincognitacostantino.online/2021/05/13/alessandro-serra-dentro-il-vuoto-teatro-gioco-e-sovrannaturale/
Before the footer the system ask to me to log-in to leave a comment.
How can I manage it?
I deactivate also these option from JatPack Plug-in.
Best regards,
FCM
Please make sure this option is disabled => https://www.screencast.com/t/fDb2iLi5, also, if you disable the option from the JetPack plugin https://jetpack.com/support/comments/, please clear your cache (also, the browser cache).
Solved, thank you!
