I receive a message from newspaper admin panel like these (for example)
An issue has been encountered while trying to validate your license key
Please reset the key from the System status tab and try to activate it again, or contact our customer support team at contact@tagdiv.com.
If you don’t have a valid license key, you can get one now and continue to enjoy the full benefits of this great product.
Buy Newspaper Theme
When i work on a template and try to add a block (i.e.) it does not appears, it maintains “thinking” and is not loaded. I have 2 licenses bought from 2 different accounts in envato:
Newspaper (www.trplane.com) 81a248832-2b36-4a20-a109-xxxxxxxxxxxx (working with no problem)
Newspaper (aesidu.trplane.com) 86fc1a79-7175-4336-9859-xxxxxxxxxxxx (provisional until web is finished)
What could it be?
Thx
I have done it with no result… in the console of wp appears the following error (sorry in Spanish), any suggestion?:
La API REST ha encontrado un error Rendimiento
La API REST es una forma en que WordPress y otras aplicaciones se comunican con el servidor. Un ejemplo es la pantalla del editor de bloques, que se basa en esto para mostrar y guardar tus entradas y páginas.
Al probar la API REST se encontró un error:
Variable de la API REST: https://aesidu.trplane.com/index.php/wp-json/wp/v2/types/post?context=edit
Respuesta de la API REST: (http_request_failed) cURL error 7: Failed to connect to aesidu.trplane.com port 443: Connection refused
We can take a look so, please contact us via email at contact@tagdiv.com and provide the wp-admin and cPanel login and the license certificate and purchase code.
