Problem with link color in post
I use the default template for post on my website.
Since the last update, I have a problem with link colors on post and I don’t know how to fix :
View post on imgur.com
Could you please help me ?
Many thanks
Please let me know how you have set the color for the links. Please provide the link to your website.
https://overclocking.com/unboxing-colis-presse-intel-avec-la-msi-meg-z890-unify-x/
Please let me know how you have set the color for the links -> I checked everywhere and I don’t see where I can change this setup.
Many thanks
Did you change the accent color from theme panel? You can try to use this code
.td-post-content a {
border-bottom: 2px solid #f70202;
color: black !important;
Set the code in Theme Panel – Custom code – custom CSS.
It’s works Thank you !
but now everything is underlined and in black.
How can I make the links deep blue only please?
You need to use this code then and set your code color.
color: yourcolor!important;
and for your first question :
  • This reply was modified 2 years by Jeromes.
Thanks a lot for your help
Just one last question please about this topic
Do you think it’s possible to use a custom color ( #127345 ) instead of blue/dark… ?
Yes, please set the color here
color: #127345!important;
