Problem with load post
I’m having trouble with loading posts. I get information from visitors to my blog that posts sometimes do not load in the “load more button” option.
Here’s the problem on IOS on chrome and safari – hasn’t been working for a week or so. Before it worked, I didn’t do anything at that time (didn’t install new plugins etc). On windows is work.
There is also a problem with turning on traditional pagination. After going to the next subpages, the posts are not visible.
I have the newest version version of WP and newspaper
Site is piekielniszefowie.pl
I think the pictures didn’t load
Problem with “loadmore”:
http://kobieta.civ.pl/loadmore.jpg
Problem with pagination:
http://kobieta.civ.pl/pagination1.jpg
http://kobieta.civ.pl/pagination2.jpg
I believe that the problem with the load more it can be caused by something that is blocking the admin ajax request to load other posts. This can also be only some settings from the cache that interfere.
The problem with the pagination, I believe that it is do to an option that was set with tagDiv Composer to the row with the loop posts to hide the row on pagination -> https://i.imgur.com/xjbVxja.png -> https://i.imgur.com/sL05OEF.jpg if this is selected and the post loop is in the same row this will be hidden when you’ll change the page.
