Problem with loading adsense responsive ad AMP
Thanks for the theme, for a couple of weeks we have a problem. We trying a lot, we have still the issue.
We used the latest version of Newspaper with Google AMP.
We need to show the ad in AMP. For this we editied the adsense info with the ca pub and the other fields. All fine.
The problem is, we not see any ad in the AMP. We trying to clean the cache and a lot of changes in the config, no result. We see a fast adsense loading screen.
ad works fine on a non-amp page.
image AD settings: https://technieuws.com/wp-content/uploads/2018/09/adsense-ad.png
image Result: https://technieuws.com/wp-content/uploads/2018/09/adsense-ad-2.png
AMP validator, no issues and green.
Other non tagdiv AMP plugin works fine.
Ad block is a responsive format
Do you know any solution for this?
Website Technieuws(dot)com
Thanks,
Same issue here. :/
Same issue..
It works as properly if you will check with the Mobile emulator if you are on the desktop, as you can see here -> https://www.screencast.com/t/IUiGSEV5
