Hey, I want to lock my content on mobile, but even when I did it in admin panel, on mobile everything is showing up.
And second thing, I want do delete “EXCLUSIVE” word, is it possible?
Thanks for help!
Page: https://warszawa.media
Unfortunately I did not find a post that would be blocked with the locker, can you please provide a link to one?
Also, I see that you are using the mobile theme plugin, please disable it and the the responsive version will be applied on mobile, then should be no problems with the posts that are locked.
The exclusive text can be changed from the theme panel -> https://i.imgur.com/C2TXK8p.png also, it can be set per block with tagDiv Composer, select the block and search for exclusive -> https://i.imgur.com/DtAwQGA.png
