problem with mailerlite
I’m trying to embed a MailerLite form in the Newspaper theme, but it doesn’t display when pasted into a Newspaper block (HTML/custom block). Sometimes I also get a message about incorrectly embedded code.
This is on a dev subdomain: dev.kulinarnyblog.pl.
Do I need to install the MailerLite WordPress plugin, or is there a recommended way to embed forms (specific block, shortcode, hook)?
screen1
screen2
All our Newsletter plugin does is provide some designs for the newsletter you will be using, in this case, MailerLite, so what you can do is set the embed code provided by MailerLite with the tagDiv Composer in the column text or title text https://imgur.com/DSSni9j, and the newsletter will display.
Which projects support mailerlite?
You can use Mailerlite with all pre-built websites, just use the method mentioned above and not the tagDiv Newsletter plugin (set the code for Mailerlite with tagDiv column text or title text https://imgur.com/DSSni9jComposerP).
So what is tagDiv newsletter? How do you use this add-on?
The tagDiv Newsletter plugin only provides a layout for the three mentioned newsletter types; it doesn’t include any additional functionality. In most cases, the code provided by MailerLite and Feedburner does not render correctly (MailChimp is usually the only one that still works as it used to). However, since some users still rely on this plugin, we cannot remove it.
What we can do is guide users on how to embed their newsletter code so everything functions properly.
Thank you for being so understanding!
