hi, i have a problem with my main menu,
if ist normal the submenu works !
if i scroll down and it change to the smaller menu the sub menu jumps to the right side, its not longe centered …
here are screenshots
normal:
http://inselleben.es/wp-content/uploads/2016/05/menu_normal.png
wrong:
http://inselleben.es/wp-content/uploads/2016/05/menu_error.png
thanks for yout help
to jump over the maintence mode use:
user guest
pw guestguest
I mean it Jump to the left Side
If it Change to the samrt snap Menu
Hello olivervossmann,
I have checked your website and I saw your mega menu. It seems to be a conflicting plugin. Please try to disable all the active plugins, leave just Visual Composer to active, clear all cache and install only the plugins that come bundled with our theme. Also, you can compare the mega menu with our demo preview and there you can see that this feature is working fine. Also, please ensure that you have correctly set you mega menu according to our documentation here -> https://forum.tagdiv.com/mega-menu/ Also, if you have any additional customizations please try to remove them and see how it works.
hi catalin,
the problem is still present even though I followed your advice. I can create an admin account, where should I send the data to? Then you can look for yourself and edit it eventually.
thank you very much !
oliver
If you have ensured that you are using the above steps and if your problem is still there, please send us an email at contact@tagdiv.com with your log-in information (wp-admin) so we can further inspect your issue. Also, please provide the link of this topic so we can identify you.
