Problem with mega menu
Hi, I ‘m using newspaper in http://www.ganasdevivir.es
Mega menu works well in the item of “agenda” ” magazine ” or “news”. However in the ” VivirTV ” the thumbs will not be aligned.
Can you help ?
The megamenu was not designed to work on rows, that why you have this issue. You have changed the number of post displayed on megamenu from the code and get this issue.
You can try this css code in Theme Panel > Custom Css if you want to use the megamenu like that: http://screencast.com/t/BQ0CaXA9PU0
.td_mod_mega_menu:nth-child(6){
clear: left;
