problem with megamenu on chrome
I have found an issue with the megamenu submenu when using chrome.
on my website kentnews.online , if you go to the lifestyle submenu, you can see all the mini pictures
If you go to any other page (such as an article or the News page from the main menu), then try the same Lifestyle submenu, the mini pictures do not load for any tab, you just see a plain grey box for the article pictures.
This has happened on all pcs i have tested with chrome.
It works okay on firefox
Hello !
You are facing cache issues on your website. As you can see from the homepage your website is displaying the mobile theme: https://www.screencast.com/t/WrzUc7xBm
Please clear your cache and try again.
I have cleared the cache and the problem is still happening
Hello !
As you can see here this works: https://www.screencast.com/t/nbTQH0Bh As mentioned above, you have some kind of cache because the mobile theme is still being displayed on your homepage. You could contact your host and let them know about this if they have caching options.
No, it is still broken, plus my homepage has been broken by Catalin. The first time you go to ALL it shows, but if you mouse down the list (General / Food / etc..) they all disappear
Hello !
Your page should be now fixed.
Please re-check and let us know !
yes, the page is fixed and the megamenu issue is also resolved, thank you
