Hi there,
No matter what I try I cannot get the megamenu to display in my theme. I’m building the website here: http://janet-love.com/news/ and the News link on the menu is meant to be a megamenu but it’s not showing. Any help welcome!
I have checked your site and found these errors in console – http://screencast.com/t/GVPln4ZRT
Please deactivate all plugins, leave just Visual Composer active, clear cache and check again if you still have this issue with megamenu. If your issue is solved please activate your plugins one by one and see which one caused this issue.
Did you disabled that plugin as I have checked your site again and you still have errors in the console and your megamenu still not working.
Alin [tagDiv].
You have to do the same like I suggested above to see what plugin cause this issue or maybe it is a conflict between more plugins. Only like that you can find where the the problem is.
These js errors usually are caused by plugins that conflict with theme javascript. Please make sure that you have disable all plugins when you check this and also clear cache.
If still have this issue please send an email at contact@tagdiv.com and provide wp-access so we can take a look, also paste a link to this conversation so we can know who you are. We will answer to this soon as possible.
