Dear Support-Team,
if I set the menu background color to a custom color it is active on all categories, posts, tags and pages without page builder… So far so good!
But on the homepage (made with pagebuilder) the menu is only black. Nevertheless the snap on menu has the correct color…
I Tried several things but nothing was helping out. Please give me some advise to solve this problem and make the menu background color working on Page Builder also!
That would be the case when using the overlay menu page template
– https://www.screencast.com/t/6rNym0RDBwuV
The header menu will be transparent when this page template is selected (overlay), but only on that page. Change the page template if you want to display a background color for the header menu, on that page.
