hello, i just bought and applied newspaper 7 to my website. The problem i have is in the main menu where i get this ( http://prnt.sc/c3luf3 ). How can i remove the duplicated categories?
Thanks in advance
P.S. This theme is amazing
Hello euklidis,
I have checked your images and I saw that your mega menu is not right set up. Please notice that this type of feature uses only the subcategories and sub-categories. -> http://screencast.com/t/NMhnFvtaTlx http://screencast.com/t/GO8fRib2WhbE For more information about mega menu, please check here -> https://forum.tagdiv.com/mega-menu/
I cannot find the way to fix this like the tech sample page. whatever i do the same problem appears. I add a menu with subcategories and declare the mega menu to point on it self. Is that wrong? http://prnt.sc/c9sbau
It seems that you have not created the mega-menu properly. That is why it breaks. You will have to remove the sub-categories in the menu element before making it a mega menu. You simply add the parent category and select the mega-menu option;. The theme will grab the subcats automatically.
example:
wrong mega menu: http://screencast.com/t/v1WzLENdw
right mega-menu: http://screencast.com/t/82UzWTWUjVx
You can read more about mega-menus here: https://forum.tagdiv.com/mega-menu/
