Problem with Menu & Search Icon on Mobile
Hello there is Problem with Menu & Search Icon on Mobile….please see the screen shot and advice these icon are sticky with the browser top.
https://s15.postimg.org/6zosteg7v/Screenshot_20161128_073949.png
Also, under mobile theme i am also disabling the footer menu by selecting –no menu– and pressing save settings but always it is replaced by some menu please advice that also.
Please provide a link to your site so I can inspect it
Website is lethow.com
I tried disable all plugins, cleared cache and reset cdn files. PLease advice how to restore the theme line height?
Also, please see the following custom code is in mobile theme…
.td-post-author-name div { display:inline; }
.error404 .td-a-rec-id-header_mob, .page .td-a-rec-id-header_mob {
display:none;
@media
(max-width:767px){
.td-author-line{
display:none!important;
@media
(max-width:767px){
.td-mobile-footer-wrap{
And Below is the custom code in Desktop Theme…
.td-author-line{
.error404 .td-g-rec, .page .td-g-rec {
display:none;
I had checked under theme fonts>> fonts settings and line height is default line height in all settings.
Moreover, you can see search icon is also not on its location on desktop as well…it is a line above its position….this is the same in mobile menu and search icon and 1 line above…
  • This reply was modified 9 years by lethow. Reason: more details
You can close the issue it is resolved now…
