Problem with migration
Hi, how are you? I have a problem after site migration. Nothing works and I do not know what the problem will be, update the links.
This is where I have to migrate the web http://aefipcapital.org.ar/2017/
And this is the original that works perfect http://aefip.chali.com.ar/
I appreciate your help
You could use the Duplicator plugin, it seems to be the most recommended method for migrating websites
http://www.wpbeginner.com/wp-tutorials/how-to-move-wordpress-to-a-new-host-or-server-with-no-downtime/
More general and useful information here
https://codex.wordpress.org/Moving_WordPress
The theme also has an import/export feature for theme settings
https://forum.tagdiv.com/import-export-theme-settings/
Also check these parameters for the new location to be set properly
https://forum.tagdiv.com/system-status-parameters-guide/
