Good morning! I would like to ask for help in resolving a problem with the mobile version. For many years everything worked correctly. Currently, just before the update, the mobile site broke (as shown in the attachment). It does not look like it does in the TagDiv preview. In Composer, I installed the Newspaper updates, reinstalled the Mobile plugin, and it still doesn’t work. In Newspaper → Theme Panel → Mobile Theme, I have Mobile + AMP set. In the TagDiv Composer preview everything looks fine (as in the attachment), but it does not load correctly in reality.https://autoelectromoto.pl/zrzut-ekranu-2026-01-12-o-20-31-58_11zon and https://autoelectromoto.pl/img_2598_11zon/
If you want to use the responsive version from tagDiv Composer, you should not use a mobile theme plugin. Alternatively, you can use it only for the AMP version, making sure that AMP does not redirect users automatically to the AMP pages. In this case, AMP should be used only for mobile users and to obtain some results in Google.
Colin, thank you for your help. I’ve deactivated the mobile plugin, but it still displays incorrectly on phones 🙁 Do you maybe have an idea what I’m doing wrong, or what might have happened that the TagDiv preview version is being displayed?
I can see that you’re experiencing the same issue on desktop as well https://i.imgur.com/448L9qe.pn
Please clear the cache first. If the problem persists, check whether the “Remove Unused CSS” option is enabled. If it is, disable it and then clear the cache again. After that, please check the results.
