Problem with Mobile Appearance
Just a quick question. I cannot figure out how to make the padding/margin disappear from around revolution slider on my mobile homepage. I have adjusted settings in visual composer, style.css, and the slider tab to no avail. Firefox says that the css container is .td-main-page-wrap and/or .td-main-container-wrap, but neither of these affected mobile output. Please see the link for annotated jpg of my problem. Any help would be greatly appreciated.
Mobile Appearance Issue
  • This topic was modified 11 years by Fritch.
The problem in the mobile version comes from the visual composer row settings. I have tested this myself and found that a full height row and other settings will cause this effect on the mobile version. These visual composer row options were not adjusted to work with the theme 100%. We usually recommend the default values set on the VC row. In your case you can use the default values on the row and just select the stretch row no padding value.(you can try different variations to see different results)
http://screencast.com/t/XFwmQ3xUeGL
Let us know how it goes.
Hey Bogdan,
I had the ‘full height row’ checkbox selected and this was causing the extra white space around the slider on mobile.
Thank you for pointing this out for me.
