Problem with Mobile Format
Hello, i’m using newspapers theme on my wordpress site, but many times the theme show the mobile version when i access the site by my notebook.
I’m using varnish cache on my server, could it be the problem?
It’s my site –> http://zipbr.com
Yes,
I had the same experience.
If properly configured on the server, you don’t need the plugin
  • This reply was modified 9 years by nairolf.
HI
@hermesaajr
yes it could be a issue caused by cache so try to deactivate the varnish cache from the server then test the site again.
It’s the problem, i can’t disable varnish cash i have many traffic and i need it to keep the server up.
Would exist an anternative method?
This is clearly a caching issue so you should switch your caching method. We only recommend wp super cache with our theme but we cannot say for sure about server side cache. You will have to try with a different caching solution as there is no alternative we can provide.
