Problem with mobile homepage
Hi, I have a strange problem that has occurred after updating to Newspaper version 11.5.1. Every time I edit my homepage with tagdiv composer on desktop version, it saves but also over-rides the mobile version so that it serves the desktop version on mobile as well. I can fix this by editing the mobile version of the homepage, but this then serves the mobile version on both mobile and desktop.
I think I have temporarily fixed this by going into the pages menu on wordpress wp-admin and editing the mobile page that is listed there in addition to the desktop homepage separately. But I am going to have to do this complicated workaround every time I edit the homepage now which is annoying.
The homepage and mobile homepage were created on an older version of the cloud templates system and they are only editable in the wp-admin through the regular Pages menu, they do not appear in the newer Cloud templates menu under Page templates > Homepage templates. Any idea how I can fix this? The website url is https://www.solidarity.net.au/
Actually the mobile page has been replaced with the desktop page again and seems to keep reverting back that way automatically. I have also noticed that none of the mobile pages on my category page cloud templates display properly either. The only one that seems to work is the mobile page for Single page template.
I have deactivated unsupported plugins I am using one by one and it does not fix the problem. I have noticed however that when I login to wordpress wp-admin this seems to fix the problem.
Hi jsupple05,
Form what you say, there are more problems, and I will be more the happy to investigate them and help to fix them. If you agree, then, please do a full backup for your website and please contact us via email at contact@tagdiv.com and provide wp-admin access. We’ll check it as soon as possible. Also, please include the link of this email to identify you easier.
