hello.
i have tried to set up my site to work on mobilie and it doesnt work at all.
it wont show the menu, and my pages are blank.
cant you provide me with an email to our support so i can explain further and
send pictures to show my problems ?
Hello !
You can post here your issue and we are going to try our best in solving it. From what are you saying it appears that you are using the Mobile Theme plugin. The Mobile theme was specially designed for optimization on mobile devices. Unfortunately on mobile theme you cannot do much changes of design. If you want to have the same design as on desktop mode you can achieve that by simply disabling the mobile theme. Cloud templates are included. They do no work while having mobile theme.
In order to have the content of your pages on mobile theme you will have to recreate the page in the mobile editor wich can be found at the bottom of the page editor as you can see here: https://www.screencast.com/t/g8FDdPqTetf
Please provide a link to your page so we can inspect the menu issue also !
