I’m using Gossip Cloud Template for Desktop version and created a mobile page version from the same style. The problem is that when I visit through my mobile phone, most of the times, the Gossip Style doesn’t load, and I only get a default style for single page. I’m running a FB campaign and just had the bad news when I clicked on my own link đ
here is my template config.:
https://imgur.com/a/WGNSnMv
https://imgur.com/a/Globe3I
here’s how it looks when I access from my phone through chrome and FB link:
https://imgur.com/a/ZRxr4tJ
here’s when I access from my desktop and change to mobile view…. seems ok…
https://imgur.com/a/sXI5cNS
Im not using AMP… I just want to understand why sometimes it loads the mobile version I want and sometimes a default version… :S
Link: https://shevibe.co/como-curar-a-tosse-em-2-minutos-dicas-rapidas-e-eficientes/
I checked and look like this https://i.imgur.com/KIce1bv.png , I saw that you didn’t convert the header; so you need to convert the header and footer -> https://www.screencast.com/t/HrjOBNayd please check this video https://www.youtube.com/watch?v=SpGkOnJeNZY What cache plugin you use? You can check if the plugin has a separate cache for mobile, if the plugin has one, please enable it.
Also, I donât fully understand what issue you have there; what is different?
