Problem with mobile theme
i have Newspaper 7.4 installed with Travel Blog demo without content. Everything works fine, except the mobile theme. No Slider and the columns are spelled in englisch. mobile theme installed, and set to standard settings.
On the mobile, if i switch to desktop version, and then back to mobile version, everything looks fine. after viewing some sites, the right thing is gone.
tested mobiles: android mobile with chrome installed. samsung tablet with chrome installed
thanx.
sorry, forgott the domain: http://www.camperei.de
Ok, found the Problem:
you have to disable the mobile theme. then everything looks like in Desktop browser with slider and everythink correct.
if someone has the same problem.
