Hi guys,
i have an issue with a mobile view for the page on the site.
This is the site: https://imprenditorefacile.com/blog
I can’t see the page if i don’t scroll.
Do you have any solution for resolve this problem in mobile version?
Thanks a lot
I’ve checked your website and I can’t see any issue. Which browser do you use? Please provide more information about your issue.
Thank you Bettina,
i record the problem by iphone via Safari, the same problem in android and chrome on mobile
This is the video
Our demo works well on those browsers, so it should be something on your end that interferes.
Make a test and deactivate all plugins except tagDiv ones. Also, if you are using a cache plugin, deactivate it, clear all cache, and try again.
Let me know the results!
Isn’t there a way to disable this solution? Since it is not a page loading problem but if there is no scrolling or a tap it does not show the page
