problem with modal
Hello
I have a problem in the way that the content of a modal is being displayed, the option “Show modal in composer” shows it perfectly, but in the URL of the site it looks bad.
this is how it should look
https://echez2024.wpenginepowered.com/wp-content/uploads/2024/04/modal-tagvid-perfect.png
Bad
https://echez2024.wpenginepowered.com/wp-content/uploads/2024/04/modal-tagvid-bad.png
Please let me know how you have created the page and what element you use to add the text.
Hello Anamaria, I sent you the screenshots
Taxonomy called “Ofertas laborales”
Taxonomy Template
Modal Create
https://echezgroup.com/wp-content/uploads/2024/04/Captura-de-pantalla-2024-04-15-1402809.png
Do you speak Spanish?
thank you!
I added to the above that
Individually, the info looks good
But within the modal no
https://echezgroup.com/wp-content/uploads/2024/04/Captura-de-pantalla-2024-04-15-144246.png
Can you tell me what is not looking good? If you are referring to the background, then you need to set this in the modal popup element. Also, if this is a CPT, then it will not work on the modal popup. There should be only pages, so please create a page using the element column text to add the text.
