Problem with module big slide
Hi, sorry for my english,
I bought Newspaper 4 and my url is http://www.fancityacireale.it/wordpress2/
I inserted the module big slide in my home page but when i click on the article title the link not open the destination page
can you help?
I have already asked the support VisulaComposer and their response was:
Hi davide,
Most likely the “Big slide” module/element is coded by the theme author as we do not have it in our standard package. You can check our standard package elements by logging in here: demo.wpbakery.com/vc/wp-admin/
I would suggest you to get in touch with the theme author, for any issues related to this element as we are not aware of the code that is being used in it.
thanks and sorry
Davide
This issue occurs because of Yoast Google Analytics plugin which you also use: http://screencast.com/t/h0t335sofp8z We know about this and we have already wrote to plugins author so we can find a solution for this, you can also write to their support page: https://wordpress.org/support/plugin/google-analytics-for-wordpress
We are trying to fix this but unfortunately is more difficult than we initially tooth. You can disable this option from Yoast Google Analytics general settings, will fix the issue with the links: http://screencast.com/t/LRV9LlBn3 or you can also use our own Google analytics support (just paste the code in our admin): http://screencast.com/t/EtxOCuXlspj
Sorry for the inconvenience!
