Problem with Molongui plugin
I am using on this address http://www.dite-aisre.it the theme Newspaper
If I activate the Molongui Authorship plugin everything seems to work but I have the following problem:
In the the posts loop module in home, the author element (byline) has the correct link but the label is always administrator (amministratore in Italian language). The correct author name does not appear.
posts loop
Paolo
Hello Paolo,
I just checked and now seems to work well -> https://i.imgur.com/rzWmSD2.jpg
Did you solve it?
Thank you Anamaria
But it works because the Molongui plugin is not active.
How can we make you see the site with the plugin installed? The strange thing is that when I am in editing mode you see the names correctly while when I exit the editor the word “administrator” comes back.
Paolo
Hello Paolo,
Please do a test using only tagdiv plugins and Molongui and clear/purge the cache and see if the problem persists.
