Problem with more than 10 posts in 3 columns at the archive of my blog
I’m having a problem in wich there is a gap in the archive posts when they are more than 10 disposed in 3 columns.
You can see it in this image: https://imgur.com/a/YSixO
What can i do?
“i am Facing issue with catogry display – reply #177211
Jun 7, 2017 at 9:20 am
Hello ahmedyakub,
These gaps appear because you do not use the right post limit number. You should set this limit to be divisible by 3 to fit all the spaces, from here -> https://www.screencast.com/t/lqePwNVVp
Hope this helps!
Thanks for the message!”
closed
