Problem with Multi Purpose Plugin
Greetings!
I purchase newspaper 8 from you which has this code: eab77123-b6e6-4c5e-a6b4-4f14177e9d1b. My host advise me to contact you to fit the tagDiv Multi-Purpose plugin. Whenever I activate this plugin and published my website, the following message will appeal:
wp booster error:
td_api_base::mark_used_on_page : a component with the ID: td_api_sub_footer_template is not set.
wp booster error:
Missing parameter: ‘file’
Fatal error: Class ‘td_api_sub_footer_template’ not found in /home2/atenaje/public_html/africanstar.org/wp-content/plugins/td-multi-purpose/td-multi-purpose.php on line 1316
Thank you and be informed that the plugin in question is inactive presently.
Yours,
Jacob Grody Dorbor
Please update the theme via FTP way, clear all the caches, purge CND files and check the results. If the problem is still there, please send us an email at contact@tagdiv.com with your log-in information (wp-admin) so we can further investigate it closer your setup page.
