Problem with my homepage
Hi there,
I have this problem with my homepage
My homepage
I try to deactivate all my plugins… but nothing happened 🙁
Please can you help me?
http://www.ilvergante.com
Please check your widgets area and remove all elements under footer 1, 2 and 3: https://www.screencast.com/t/5fRvVTaPT
There is most likely a piece of code there that does not function properly.
It could also be a plugin conflict so please disable all plugins except the page builder, clear cache and reset cdn files if you use it. Please also check any custom code you might have added to the theme panel or the theme files. If you use a child theme, please switch to the main theme to make sure it does not affect the proper functionality of the theme.
