Problem with my post
Today, when i update newspaper 7.8 and access in new post or old post
it show:
View post on imgur.com
Not the same old! how to fix it ?
Please provide more details, as I’m not sure what you mean.
Also please make sure you have updated the theme properly and all the files were uploaded properly and check it without any plugins active except Visual Composer.
Not ok
it’s ok
Please provide a link to your suite pointing at the post that is not ok so we can inspect it.
Please disable all plugins except visual composer, clear cache and reset cdn files if you use it. Please also check any custom code you might have added to the theme panel or the theme files. If you use a child theme, please switch to the main theme to make sure it does not affect the proper functionality of the theme.
