My sidebar goes below the content instead of at the side bar . It shows properly on the front page , but on posts page the problem exists.
What do i do
http://www.evatese.com
Hello Ivatese,
I tried to inspect your website and I got the 503 error, as you can see here ->http://screencast.com/t/v6n0SQloFU Please notice that this type of error is generated by your dedicated server (hosting provider). Tell them this issue for fixing it and tell us know when we can inspect your website so I will be able to provide a more accurate response. For more information about this error, please check here -> http://www.checkupdown.com/status/E503.html
Hello Ivatese,
I have inspected your website and I suspect being an HTML problem wich generates the entire issue for your posts. Please try to check the HTML for your Ad code, everywhere use the advertisement to not be in HTML syntax errors. Also, please try to use the theme only with the plugins that come bundled with the theme and disable all of them which are untested and wich can cause some unknown issues, clear all your caches, purge CDN files if you are using the CDN system and check again the results.
If your problem is still there and if you need more guidelines in this regard, please send us an email at contact@tagdiv.com with your log-in information (wp-admin) so we can further inspect the issue. Also, please provide the link of this topic so we can easily identify you.
