Problem with my site
Hello, i installed the theme in my website, but i still not get the homepage to work correctly, from templates, please help you can view a live example here :
http://www.tagweightloss.com/
I delete all plugin and left only needed by the theme, and still have the problem, i have no cache installed and everything, i get only this problem with that website, i try with a new wordpress installation, and everything is ok!
Glad you have managed to fix it, thanks for lettings us know!
Please let me know if you have any other theme relate issues!
Thanks for your reply, i still get the same problem with that website! i don’t know why, can you check please in the url, i left the homepage with the error !
I have checked your site but it seems that you have switched the theme to a WordPress default theme so please switch back to newsmag and let me know and also provide more details about the issues you have using it as I have checked your site yesterday and haven’t seen anything wrong.
Please let me know!
If i don’t get a quick answer, i can resolve my own problems 🙂 it appear that i already have Newspaper installed in the website! i install a plugin “database reset” and i reset all option from the wp_options, and i get a refresh wordpress ! everything work fine i have newsmag installed i am trying to se some config !
Glad to find that you have managed to get this done!
Sorry fro the delay, we do are best to offer our clients the best support we can unfortunately delays may occur sometimes as we also work hard on improving our products.
Thanks for understanding and for your message!
Hello, i disable the Visual Composer, and i am happy with the result, what i can lose if i disable this plugins, i don’t need the homepage design etc ! i am happy with the blog results! For the widget, i still have the Tagdiv blocks ! so whats the purpose of the VC other that create a homepage or some other pages ? Because the VC get my website Hell slow !
The VC plugin is used to build homepages using the theme’s block elements/widgets. Without it the blocks shotoces aren’t interpreted as they should therefore the page layout breaks.
You will still have the block widgets but I can’t tell you how they will work this way so if you like the result you have without it you cannot use it.
