problem with my template
Hello
I did a template with the TagDiv Composer.
I wrote a post and everything was fine.
After one week I used the same template to do another post.
I wrote the new post, but my first post changed too.
Both have the same text new, the new text.
How can I make change in the text for just the new post?
Thank you
Eduardo
Hi oyarseeduardo,
I hope that you made the posts using the WordPress editor and you made the single post template only for the post layout (this is the scope of cloud templates), after that you only selected that cloud template as individual or global.
The single post template must have the “Single Post Comments” element set to display the post content from WordPress.
Hello
Thanks for your answer.
I did the template with the tagDiv Composer, but I filled the data in the same screen.
First I made the template, the. I selected the template in the editor, but there I can’t see the layout.
How can I fill the template when I am in the editor screen.
I understand that the editor screen is a blank screen. I can just write the title and the paragraph, cite, image…
But I can’t select the place in the template where I want to put my text.
Thanks for your help
Eduardo
The simplest solution would be this one:
– import a single post template from cloud and set it as global -> https://i.imgur.com/n4Z3Jsy.png -> https://prnt.sc/3Gb1lvpT8q1E
– create post using the WordPress -> https://i.imgur.com/kINa2z1.jpg
The results will be -> https://i.imgur.com/E8NkRg6.jpg
Honestly, I haven’t been able to fix the issue.
On my website I have created a post to put the weekly horoscope. The ideal would be to have a template. My post was
https://www.soloestetica.cl/consejo-semanal-25-de-abril-2022/
When I try to use the same template, even if I use another post name, since it is the same template that is as a single post template, all the ones used with that template are changed.
Therefore I think it would be best to write in the WordPress editor based on pure “Text with Image” shortcodes, changing the text and the photo.
The problem is that I can’t find how to access the code of that shortcode to be able to write it in the WordPress editor.
Perhaps my explanation is somewhat complex. Do you get the idea?
Thank you
Eduardo
I’m sorry, but I don’t quite understand.
Normally when you use a single post template on posts, all posts that use that single post template will look the same (this is the purpose of this single post template from cloud).
If you want to have a different template, then you can use a single individual post template.
Hello
You’re right.
I want to use the same structure, but I need to change the text.
In the tagDiv editor I selected the text with image shortcode.
How can I write the text in the WordPress editor and show that text in text with shortcode?
I didn’t find the solution.
Therefore I wrote the text in the tagDiv editor. It works, but since I wrote the text in the template, when I use the same template for another post, the text changes in all the posts in which I have used that template.
Perhaps it is better understood there.
How to make a template where you can use the text with image shortcode, entering the text and image from the WordPress editor and not in the template editor.
Thank you
Hello Eduardo!
A shortcode can be inserted in our theme only by using the element called “Column text” or “Text with title”. Now, it’s possible to be a plugin conflict there, but you can make a test on a test page.
“Column text” and “text with title” elements have a button called “edit content” and if you click on that button, the WP Editor will open and you can add some text/code/shortcode there. Close the WP Editor from X, save the changes from Composer and view the page to see the changes.
In order to avoid misunderstandings, please provide more information about what exactly you need to achieve or what the issue is, screenshots or a video.
Hello
Thank you for your mail.
An example:
I have to make a post every week like this
What dou you recommend?
I cannot do this post with my global template (image and text aside)
There is also no template in the Cloud that can be used to do this.
What do you suggest so I don’t have to create a new single post template every week?
I hope I have been clearer now.
Greetings, thank you
Eduardo
Hello Eduardo!
We do not have a feature to create a post for you automatically. Maybe you can find a plugin for that, but please take care for a future plugin conflict.
