Hi, I have a problem with my website. When I view it from the mobile I cannot access the menu. going to the three lines of the menu the site shrinks but the menu does not open. the site is http://www.professionegenitori.it, if you can take a look and give me some advice I would be grateful.
Hello Luciana!
Please edit your homepage with the TagDiv Composer, click on the mobile viewport: https://www.screencast.com/t/XDQJedlggSB, select the menu icon and check if you set up a menu there.
Let me know the results!
