Problem with Newsmag Theme in Mobile Device
Hi!
I just bought your Newsmag theme and I’m starting to edit it with one of the demos by default. At the moment I do not have many problems, except that my website is not displayed on mobile devices. I have activated Pluggin’s settings in the Theme panel -> AMP -> Page -> Enable / disable AMP support on pages, but it does not work. Please tell me what I have to do to make my website appear correctly on mobile phones.
Please provide your website URL so I can take a closer look at it.
Hi again. My website is http://www.35milimetros.es.
Please make sure that you do not have another mobile theme activate, or plugin conflict, you will have to disable all other plugins and install the mobile theme first.
https://www.screencast.com/t/o7c0lg6u It appears because you use the Jetpack mobile theme. Since the theme has already a mobile version, it doesn’t work with jetpack module.
-> https://jetpack.com/support/mobile-theme/
As a notice, please notice that the AMP for the pages will work only for the pages which are not created with TD Composer plugin.
Hi Catalin. Thank you for the help. Now it is fixed and I can see my website correctly in my mobile device.
A few questions:
How can I change the number of post which appear in Recent Articles block, in homepage?
How can I change the Articles and Popular Categories in Footer for other?
How can I translate and change the links of the sub-footer (Disclaimer, Privacy, Advetisement, Contact…?
Thanks again!
I think that you are referring to the Latest Articles section from your homepage which can be managed from Page templates (Page builder+Latest Articles). Check here -> https://forum.tagdiv.com/newsmag-page-templates/
The footer section can be changed from the Widgets area -> https://www.screencast.com/t/tT02qhCdX
For more info about Footer Template, please check here -> https://forum.tagdiv.com/newsmag-footer-templates-2/
Check the footer menu from here -> https://www.screencast.com/t/E8VyADgmUup
Thanks Catalin. All right!
