Hi!
I have:
– Newspaper 7.8
– WordPress 4.7.4
– MashShare plugin
And problem can be seen in this screenshot: https://snag.gy/750IZF.jpg
So when I write an article, select post template as “Style 1”, that happens. Text should start next to the image and share buttons should be above.
I don’t know much about coding.. could you please help how to solve it? 🙂
This could be a plugin conflict so please disable all plugins except visual composer, clear cache and reset cdn files if you use it. Please also check any custom code you might have added to the theme panel or the theme files. If you use a child theme, please switch to the main theme to make sure it does not affect the proper functionality of the theme.
Unfortunately that did not help. I deactivated all plugins except visual composer. Cache or “cdn files” I don’t have installed at all. I did not add custom code and it’s not a child theme.
It’s a completely new website (just a couple weeks old). And I did install a few plugins after installing the theme (Yoast SEO, Hide my site, Shortcodes Ultimate to mention a few)..
What to do?
Hi, The mashare plugin is not tested along with other plugins you are using now. The only tested and recommended plugins list is found here: https://www.screencast.com/t/zsBJxCubYmn
Any plugin beyond this list is not tested and could possibly create issues with our theme. Untested plugin implementation is not covered by the theme support. Sorry
I now made a completely fresh plugin-free install of WordPress on a new domain. I installed Newspaper theme, then MashShare plugin. Same problem: https://snag.gy/vIpOlS.jpg
Ok, it’s not supported, too bad. I guess I have to learn some basic coding/editing the template. But I hope you consider fixing this small issue for future updates..
