Hello (sorry for my english) i have a problem with my theme Newspapers 9.0
I have install it and i want custom the design.
I want add a slidebar widget but it don’t work
I have install defaut template :
Preview link
https://ibb.co/mvkEFz
When i have confirm this design
https://ibb.co/df038K
The widget don’t want stay next to the middle columns
I have WordPress 4.9.8, all my plugins was update.
I have activate slidebar on my theme.
My website : http://www.breakingvap.fr
So you want to display a sidebar in a page. That is not difficult. Edit the page in question with the composer, split the row like this for example (most common)
– https://www.screencast.com/t/LAj3BAlMFk
If you want to display widgets use the widget sidebar element
– https://www.screencast.com/t/5r9JLFOz
Or drag elements directly in the sidebar column
– https://www.screencast.com/t/Qg5dYC2E
In the page you mention I see the sidebar looks alright. That should be the case for all pages. What exactly are you doing in the page and what it is happening? Could you provide a link to that page so I can take a look?
I have make it but when i publish my theme the sidebar after on the middle, you can check my screen
Please send us an email at contact@tagdiv.com and provide admin login. Mention the page where you are trying to create the sidebar. We will take a look.
Include a link to this topic in the email.
