Problem with non AdSense responsive ads
(1) we add a custom ads in ads setting theme (Custom ad 1):
<div class=”td-all-devices”>
<script type=”text/javascript”>
var bannersnack_embed = {“hash”:”bxhp0uh7a”,”width”:336,”height”:280,”t”:1533483921,”userId”:21218741,”responsive”:true,”type”:”html5″};
</script>
<script type=”text/javascript” src=”//cdn.bannersnack.com/iframe/embed.js”></script>
</div>
(2) in tagDiv composer we add “Ad Box” ad set “Custom ad 1”.
We have a problem: non adSense ads size is different (smaller) from Google AdSense ads size (.
(See in https://www.driveandride.com/it)
The ad should be of the size served by the provider. The only limit would be the theme width. Try and enter the ad code in a simple text element, see how it displays there
– https://www.screencast.com/t/JPwUfkOSVQwR
There should be no difference. It all depends on the ad that is supplied by the provider, there is enough space available to display a bigger ad.
we used “Column text” instead “Ad Box” for non adSense ads and the ads size is good!
Thanks for your help.
